Audi's rim for Mercs
APR C180
Yap, aggressive means protrude too much out from the fender. Rubbing fender will be the issue. Also check the center bore is it the same as Mercs?
If you can wait, come for May's GTG. You get to ask around, can pull blackmercs away from his chio bu's, get some explanation before you dive in with your rim upgrades. Esp after a couple of our guys didn't fare so well with their initial rim upgrades.
looking for an angry fix... "
Hi bro, this is a caractere rim. Offset is accpetable if it's plus minus 5. For your case, 10 is too much, If you really like this rim, it actually comes with the correct offset for your car. If I am not mistaken, Autovox and HAT carries them (may need to order).
Sorry it's WWW.VAG.SG
thanks for the info as still deciding on which 18" to replace the stock 17" and found that this caractere rim will look special on a Mercs.
Design special leh, surprisingly lighter than the norm AMG rim..,,
Follow yr heart, is a yes for me. M T L!!
I am a sucker for AMG rims too bro, but frankly, there are tons of rims out there lighter than the AMG rims. And best they are not staggered.
I have been thinking about the AMG rims for a long time Liao.....the higher fc and faster rubber wear is the only reason I'm still stock!
LS do have stock for 18" with ET35 offset, was advice 18x8 will not rub fender but 18x8.5 and above will not clear. Centre bore also no issue...still deciding to chg or not....
I'm fat so i avoid offset 35.
If i get any fatter, likely to rub.
for 8j, 35 offset will be very nice at the rear.
Front too aggressive for my liking.
gonna have mud splatter all the way up to my door.
Chio leh!! This is audi rim leh!! Lolz just kidding
Offset is 35 all round? Snap a few shot on the side view. Come to gtg ya to show us new found!!
Yep, 35 with 18x8 all round...quite flush from the side but just compare to my previous ride....... :crazysmile: :crazysmile:
Fierce! Hope u didnt lowered yr ride :). Hmm 35 offset for W204 u are da man!! Tyres size?
Still stock, no intention to lower, can only use 225 as other than that may rub...
Can furnish full details of the tyres size? Newbie here for this offset!!
