Tyre Pressure Sensor?
MrAYeo
  • Replies 3
I believe it is the “Tire pressure loss system” which is different from tire pressure monitoring system (TPMS) found in higher end models.
The “TPLS” monitors and compares the number of revolution each wheel made over a distance. If one of the tires is loosing air, the overall diameter of that particular wheel will become smaller and making more revolution than the other wheels.
It is not as sensitive as the TPMS that physically measure and monitor the air pressure in each tire but it is better than none.
Try to Google Orange TPMS. An aftermarket device plugged into ciggy socket. There are other brands in the market as well. I had Orange TPMS in my prev ride, quite convenient for checking tire pressure if u lazy to pump air every month.
Think one of the bros here has one in his coupe.
