7G Tronic Models
Guest kevh0
Hi Bros,
Quick question, for all you guys driving the 7 speed automatic transmission models, does the display screen show which gear you are on when in auto mode?
If so, do the gears shift from 1 to 7 or 1 to 6 and then D?
Guest hkhamateur
kevh0 wrote:
Hi Bros,
Wow....our bro kevh0, sound serious n urgent! :shocked:
Any bros? Quick quick! :llama:
Thanks Guys,
I wanted to check cause I underwent a transmission overhaul this year in June and Mechanic who did it said he changed it to the 7 speed auto transmission but on my display, when I go on manual mode, it changes gears from 1 to 6, then D.
So I wanted to check if other bros with 7 speed transmissions have the same thing as mine or is it from gears 1 to 7..
Thanks Bro Skid, much appreciated
Guest blackknight
kevh0 wrote:
Thanks Guys,
you drive a CLS right? the car is using a 7G already...so dun understand what the mechanic meant when he said he changed it to 7 speed auto?:becky:
Ya man!! For a moment i thought his mechanic able to swap 5g to 7g engine.
As for the gear shift from the instrument panel show 1-6 then D.
Yupz CLS, but first gen model, not face lifted version..
I think first gen was not running on the 7 speed transmission, not too sure about that.. His remark got me wondering, hence the question!
Thanks guys!
So on manual mode yours runs from 1 to 6 and then to d also?
Hmmm, wonder why it is different from SLK's manual mode of 1 to 7?
Require enlightenment :shocked:
Guest blackknight
Thanks guys!
which year is your CLS?
Guest blackknight
kevh0 wrote:
Yupz, S mode is when gear starts from 1 and not 2.
I believe rev meter gets more aggressive compared to C or E mode too..
Thanks for the updates bro!
are you joining us for the meetup soon?
Bro kevho, pls do this simple test in manual mode. When the gear is at 6, watch the the tacho when you switch to D. If the tacho drops, then you're in 7th gear.
On another note, my CGI has 5 speed, in manual mode it changes 1-2-3-4-5-D. From 5-D, no gear at all.
Guest chiaster
Doc, you mean when you switch to "M" mode, is that right?
I only have "C" or "S" on mine and when i am in "S", i can't recall if mine went 1-2-3-4-5-D or 1-2-3-4-D... hmmm... go test after i get away from my desk... :Cry:
My AMG sports package has M mode. But I'm referring to the manual shifts either thru the gearstick or paddle shifts while in D mode. For my case it's 1-2-3-4-D. From 4-D, it's merely changing manual shift back to auto, no change in gear ratio as it's a 5 speed tranny.:becky:
Thanks Bro jtang, will do the test when I can..
It should be a 7 speed transmission if thats the case..
Back to the drawing board for diagnostics :Cry:
Bro chiaster,
I think yours is like mine, m mode is done via gear knob shift, push gear knob to the left and its dropping down by one gear, to the right and its up by one gear :becky:
Hope that helps!
Guest chiaster
the AMG ones have "M"-"S"-"C" on the little button at the gearbox... the rest of us should only have "C"-"S" or "E"-"S"...
what i meant was, the digits for the full spectrum of the gear shifts only show when you press the button for "M"?
when i am in "C" or "S", i manually shift the gear stick to the left and it drops to the next most appropriate ratio... when i shift right, it shifts up... i remember it shifts from 1-2-3-4-D in both "C" and "S" mode...
so, to summarise, please correct me if i am wrong... and this is for the 5-speeders...
"M" = 1-2-3-4-5
"C" and "S" = 1-2-3-4-D
tio bo?
:confused:
Guest subaru67
"M" = 1-2-3-4-5
tio bo?
:confused:
yes mine is "c" and "s" and if in manual mood only D1,D2,D3,D4 than D
"M" = 1-2-3-4-5
tio bo?
:confused:
Yupz I guess so.. GOt an on going issue to resolve at the moment..
Meaning going to C&C to Si & Si :Cry:
"M" = 1-2-3-4-5
tio bo?
:confused:
TIO!:becky::becky:
