aircon filter
Guest chiahien
  • Replies 25
chiahien wrote:
hi,
Can i check with e bros here, does c class came with air-con filter ?
thanks,
You can remove your glove compartment and check. But high chances that it does not come with...
Guest chiahien
e reason for asking is because while i'm driving i could smell e outside odour. so i was wondering does w204 comes in stock condition. i will check ltr. thanks for e reply !
Guest arshavin
Wes23 wrote:
Best is to open ur the glove compartment and check... Then if dun have maybe I could start a group buy...
The glove compartment u r referring to the one inside the cockpit where we put our shades right?
On the left side where your passenger seat is. It had a light in that compartment!
Have you gotten ur ride bro? We might be having a mini get together tonight... You interested?
Guest Clear Vision
Just to provide some additional information on air -con filter.
1) YES C180K and above are provided with air-con filter. The official name is called "Cabin Filter"
2) Its located below the Glove box, NOT inside Glove box. Must lie on the floor mat, remove a plastic panel about 10" x 16" (3 screws) and remove two small stainless clip and slid the White colour plastic to lower the Cabin filter. Quite a tough job and the light bulb will shine into yr eyes when you lie on floor mat while trying to remove the 3 screws. I tape the bulb while removing the cover....
3) Filter can be brought from Eng Soon or Tye Soon, $53.00 Original Merc cabin filter.
P/N A212 830 00 18
I suffer backache after renewing the filter.....haha (younger days had dismantle complete engine myself and overhaul )
Quite hard to change...for those not mechnical incline... suggest better let other workshop make some of yr money....otherwise medicine to rub.
Cheers!!!!
Guest chiaster
thanks for sharing, mate! :becky: this is very useful information for all of us! :thumb:
P/N A212 830 00 18
Cheers!!!!
Guest chiaster
i didn't see this till now... haha... thanks, bro... :becky:
been inundated with work ever since i got back and trying desperately to catch up on all the missed "readings" in the forum... :bounce:
Wes23 wrote:
Welcome back bro!!!:becky:
Dun need read. You come tonight I update you!! Hee!!:becky:
  • 1 year later...
stockist also hold air con filter as well
