Thai man marries twins...
Guest jtang
Guest desmondtoo
6008 wrote:
Heard that every man only got 1.25 litre in his life time . Use wisely bro !:bounce:
Noted with thanks Bro! Will dilute in 5 litres of water...:lol:
  • Replies 27
Guest jtang
In view of the imminent danger of twin charger technology as some bros may not be able to take it, I shall postpone this 'mod' till further notice. Don't want any mechatronics or tranny up on a lorri or worse.. picking up the pcs from the ground.
jtang wrote:
I view of the imminent danger of twin charger technology as some bros may not be able to take it, I shall postpone this 'mod' till further notice. Don't want any mechatronics or tranny up on a lorri or worse.. picking up the pcs from the ground.
Gentleman . Pls deposit your balls at counter 3 in Thailand international airport . Collect your balls back with your receipt when you are flying back . Pls make sure you collect the correct pair back . Thank you !
