Car Battery
Guest Zjared
Guest Zjared
I intended to install an additional car battery in my boot for my CCTV and recorder. Darren Auto told me that I need a very good kind of car battery that cost $599 as the normal car battery emit a gas that is harmful to my health. Is it true? I only read that car battery emit hydrogen. Anyone has experience having car battery in the boot?
  • Replies 12
Guest ricric_lo
My E90 330i's battery located at the car boot... you can take a look via the following link. Thus, I'm sure that BMW's battery won't cost :hand: you SG$599. You can buy a BWM battery for them to install.... :becky:
http://www.e90post.com/forums/showthread.php?t=292200
Guest Zjared
blackmercs wrote:
No idea abt the battery thingy. So did u pay $900 for the installation?
Darren auto quoted me $200. I was prepared to let them do but the $599 battery puts me off. So I thought I ask first before I get CHOP again. Not very familiar with car :fish:
Guest Zjared
That means I probably got bullshited again. I must be wearing a carrot head. Actually I just need the battery for my CCTV only.
Guest ricric_lo
However, they're right that most of the battery emit gas and therefore usually most of the car comes with a vent tube to release the gas outside the car while you can get a vent tube installation supposedly cheaper than that.....
Guest Zjared
I think normally a car battery cost about $100 and I tried to google abit, it says all battery leak out gas so I guess their $599 also does that. Haiz. I will go to my friend instead to see if something can be done. Why can't people just do business honestly?
I m not too sure how complicated is the installation as you want it 24/7 monitoring. The extra battery mount it on yr car need to be recharged. Hmm interesting, do seek second opinion & post yr finding here.
Guest Zjared
Yalor. I will ask my friend tomorrow. Have to go to Automega mart tomorrow. :Cry:
Guest ricric_lo
The dry type (AGM) battery not emit gas while the price may be 70%-100% expensive than wet type (lead-acid) battery...... may be you can consider but definitely not as expensive as SG$599 in any sense.....
Another issue is the dynamo of your ride may not have sufficient power to charge 2 batteries at the same time viewing aircon always on at SG....
Guest Zjared
You have been a great help. Thanks for sharing the knowledge. Any ideas on how to have my CCTV on 24hrs/7?
Probably they were trying to sell U a Yellow Optima Battery!
There are various Optima range of batteries.
They are deep cycle batteries that can go into "deep discharge"
A normal battery when go into deep discharge - i.e over discharge
and fall below 10V, U will have the likelihood of a permanent dead battery.
Whereas a Optima battery can fall below 10V and can be easily recharged back to life.
http://www.optimabatteries.com/home.php
IMHO the red Optima should suit you fine!
Like Ricric_lo mentioned that your alternator must be able to charge your 2 batteries which imho should be not a problem if U use a battery isolator.
What a battery isolator do is to isolate the battery in your engine compartment to the one that is in your boot.
In my previous W124, I had one Yellow Optima Battery in the Engine Compartment and 3 more in the boot with a 250 Amp Isolator and 250 Amp High Output Alternator.
It was for my 5 KW RMS of ICE amp power. :lol:
To summarise - get a Red Optima Battery with a battery isolator.
Try New Generation Autosound - see boss cartoon and say Unker Seah from Batam ask him to offer U a solution for the CCTV.
Or go back to Darren Auto & tell Boss Jack Seah that Mr. Seah from Batam ask him to charge U "not too much" and recommend the use of an Red Optima battery & if possible with a battery isolator.
Guest Zjared
Thank you. Will go ask from Cartoon boss. :becky:
