Bigger display screen
Guest jtang
I was at Autospritze last sat to fit a BMC air filter when I was introduced to something interesting for W204 by them. It's a OEM bigger display screen that fits perfectly on the dash without interfering the cover that can open & close. The display format is exactly the same as the current, but can add on reverse cam & dvd. The C&C windscreen reverse monitor can then be removed.
Any bro fitted this & care to feedback?
  • Replies 9
jtang wrote:
I was at Autospritze last sat to fit a BMC air filter when I was introduced to something interesting for W204 by them. It's a OEM bigger display screen that fits perfectly on the dash without interfering the cover that can open & close. The display format is exactly the same as the current, but can add on reverse cam & dvd. The C&C windscreen reverse cam can then be removed.
Interesting, what's the dimension & is it touch screen?
No touch screen lah!
Just a bigger lcd screen nia!
Seen it at AutoSpritze quite a few months back.
That bigger screen will do "justice" on the W204 than the much smaller stk lcd screen. This is so when U instal after mkt mmi with Garmin Navigation, DVD, DTV, & Reverse Camera.
Chey!' I love to touch leh!! no touch where got Shiok!'
