Basic Knowledges ... Mercedes-Benz A.S.R.
Guest Gan
A.S.R. ...... Acceleration Slip Regulation
here I will like to share with you all ...
about the Mercedes-Benz A.S.R... system
Earlier Topic A.B.S .... now A.S.R ..
This ASR ... is works together with the ABS
it meant ... the vehicle equiped with ASR ...
the ABS system is STANDARD built-in
ASR control function of
#- Brake intervention
#- Throttle Valve return
the A.S.R.... for M/Benz had few Versions ...
this ASR come @ introduce into the market somewhere year 1987 ...
at that time @ product generation ...
it was only avialable for the S class W126 (option package)
we called the ASR system ...
ASR I ...(version I).......10'87 ~ 09'89
. the system equiped with seperate hydraulic unit for ABS and ASR
. ASR storage pressure supply from seperate charge pump
ASR II ...(version II).......10'89 onwards
introduce into the Market take over the production ASR I
. ABS and ASR Hydraulic Unit combined into a COMPACT h/unit
. ASR storage pressure supply from the charge pump in the h/unit and additional charging pump
this ASR II production breakpoint start at 10'89 for Model
W126 , W124 , W201 ... (option package)
W129 as of start of Production (Standard Package)
ASR III ...(version III)....... 10'93 onwards
introduce into the Market somewhere 10'93 take over the production ASR II
mainly for W129 and W140 (standard Package)
. Hydraulic Unit design as for ASR II a COMPACT h/unit
. ASR come with EBR @ Engine Brake Regulation
. System with Module Box
. System linked with EFP @ Electronic Fuel Padel , Engine LH system ,
EZL/AKR control module via C.A.N. data line
. System with diagnostic fault code memory
. Fault Code Can be read out / erased via TESTER
...... additional function for ASR III with .....
. Advance Angle Adjustment - retarded via EZL control module
. E.B.R @ Engine Brake Regulation controlling of Throttle Valve Opening
ASR IV ...(version IV)....... 10'93 onwards
introduce into the Market somewhere 10'93 take over the production ASR III
mainly for W202 C280 (option package)
. Hydraulic Unit design with 2/2 way valves per wheel
. Uprated charging pump in wheel house (LH fender)
. Hydraulic function w/out pressure accumulator, pressure switch & charging pump
. Internal venting sequence of ASR hydraulics
. Brake fluid reservoir with additional level check switch
and the rerturn line from ASR h/unit
. System linked with EFP @ Electronic Fuel Padel , Engine FHM system via C.A.N. data line
...... additional function for ASR IV with .....
. Advance Angle Adjustment - retarded via HFM control module
ASR V ...(version V)....... 06'94 onwards
introduce into the Market somewhere 06'94 take over the production ASR IV
for Model
W129 , W140 , W168 , W170 , W202 , W208 , W210 ... etc
. Hydraulic Unit design with 2/2 way valves as ASR IV
. Self-priming high-pressure pump
. Hydraulic function w/out charging pump
. No additional brake bleeding for ASR hydraulics
. Normal Brake fluid reservoir
. Additional ASR OFF switch (for switching OFF the ASR)
. Flashing ASR warning light
. System linked with EFP @ Electronic Fuel Padel , Engine FHM/ME/MSM system via C.A.N. data line
. Additional C.A.N link with instrument Cluster (as of 02'96)
...... additional function for ASR V with .....
. safety Fuel Shut-off (for petrol engine only)
ASR is an automatic system for improving the starting off
and acceleration capability as well as directional stability.
The basic ABS and ASR components are combined in the ASR Hydraulic Unit
The ABS and ASR circuits are also combined in the eletronic system
of the Brake control circuit (you all called it ABS Control Unit @ some called ABS with ASR system)
but the actual technical words was ASR Control Unit or Control Module ...
The speed of all wheels are recorded and processed in the ASR Control Module.
If The ASR Control Module recognizes from the speed signals
that one or both wheel are tending to spin,
the ASR control mode begins.
Brake Moment Control Circuit
The Spinning drive wheel is brake/reduce by the associated wheel brake
until the calculated drive slip is attained.
ABS prevents the wheel from LOCKING when brake
and therefore maintains the steerability and directional stability
when the vehicle DECELERATION ....
ASR prevent the drive wheels spinning while driving.
it also improves directional stability with an increased traction capability
throught the entire speed range...
Driving Moment Control Circuit
in the case of the EFP @ EA @ Electronic Acceleration
the ECU are used to control the drive moment control circuit
the ECU Control using the throttle valve and ignition timing or fuel shut-off is performed.
EBR is also integrated in the ASR.
It prevents the drive wheels slipping in overrun mode and ensure direction stability.
the ABS will come in automatically to reduce the OVERRUN wheels
The ECU will shut-off the fuel system ....
or Closing up the Throttle Valve ... to reduce the Engine Torque
in case of the ASR begins , the warning light Flashes and warns the driver
that has approached the physical driving limit of the vehicle.
ASR OFF switch ....
The ASR can be switched OFF via this ASR OFF SWITCH.
The driving moment control circuit is then no longer active.
Brake intervention on one side can be effective while starting off up to a speed 40km/h.
when this ASR OFF switch is operated,
the warning light in the Speedometer COME ON PERMANENTLY
this is to remind the driver ASR is switched Off
If one or both drive wheels spin , the warning lamp FLASHES.
this applies to the entire speed range.
hope this helps .....
GONG XI FA CAI .....
