PCD for MB
Guest Pattanct
Pattanct wrote:
is PCD of rim for MB is 5x112 ?? say from C-class to S-class?
IIRC all MB PCD is 112 x 5 bolts.
PCD can be the same for C to S Class but the interchangebility may not due to the different offsets.
If the offset is much higher than your spec wheels, your wheels may touch or hit your brake rotors.
If the offset is much lower than your spec wheels, your wheels may ended up protruding out of your wheel arch and or rub against your fender during your driving.
The PCD also tells U that it can be mounted to your ride but not necessary it fit your ride without problem especially the offset.
At times width of rims will also affect the interchangeability.
