Wheel Lock bolts
Guest vratenza
Guest vratenza
Any one using aftermarket wheel lock bolts for their Merc?
I was previously using McGard spline/security lock nuts for my previous ride and it is pretty straightforward in terms of finding the correct size.
Now that Merc is using bolts instead of nuts, it's a little complicated as apparently if the bolts are too long, it may touch the rotors..if too short..the whole rim can fall off!!
As far as specs goes, the stock bolts are M12X1.5
Not sure if aftermarket rims' bolt holes can fit the stock bolt head as they tend to be narrower and deeper set.
Just want to find out what you guys are using to protect your expensive rims/BBK?
Thanks!
