New Shoes for the C
Guest rssid
  • Replies 60
Another question, after lowering with h&r springs any bros have issue like rear lower than front even without load?
Had the same issue with my FD2 and E90 when I had lowering springs on them. You can't control the height and my rear was lower than the front as well.
I had rubber spring spacers like these installed but they didn't helped much. Coilovers are the best if you need to adjust the ride height evenly.
树大必有枯枝,人多必有白痴。
树无皮必死无疑,人不要脸天下无敌!
will changing higher spring pads for the rear helps? understand that the drop is actually quite even just that the front wheel arch for most cars are usually higher then the rear wheel arch. pls advise.
Seriously i'm not a big fan of lowering springs after my experience with them so I can't give good advice. Had Teins & H&Rs, I ended up with coilovers in the end.
树大必有枯枝,人多必有白痴。
树无皮必死无疑,人不要脸天下无敌!
Initially wanted to go for coilovers, but drop the idea as my previous ride was on coils for almost 5 yrs and I wanted comfort now. Tried the softest setting on my fren's car using silvers coilovers from mcwell, still hard for me.
To be honest I didn't find the springs comfortable as well. U want comfort must stay stock lah.
树大必有枯枝,人多必有白痴。
树无皮必死无疑,人不要脸天下无敌!
