Comand aps gb
Guest Cerano
Guest Cerano
Hi guys
I have an absolutely awesome opportunity for you guys here.
I may be installing my Comand APS soon. An installer from the UK may be dropping by soon to install for me.
Kindly indicate your names below if you are interested
1) Cerano
2)
3)
4)
5)
6)
7)
8)
9)
10)
It is 995 pounds for the Comand FULLY INSTALLED WITH GPS AND INSTRUMENT CLUSTER PROGRAMMING.
However, it is only single disc changer. If you want the 6 disc changer, you have to top up 600 pounds more.
And if you want Comand to appear as a factory option on your vehicle's datacard (when hooked to the star diagnostic) it will be around 100-200 pounds more.
BEST DEAL AROUND
Guest Cerano
Hi guys
An installer from the UK may be coming down to install Comand on my W204. However, he can install for any model.
Payment wise its COD.
Will take 1-2hrs per car.
It is 995 pounds per installation complete with SCN Coding
GPS and Linguatronic will be enabled as well.
note: this does not include central air vent and switch for tilting the display.
for 6 CD changer you will have to top up 600 pounds.
the installer can also change your vehicle datacard to reflect that Comand APS came as a factory option on star diagnostic. fully OEM parts.
1)Cerano
2)
3)
4)
5)
6)
7)
8)
9)
10)
to put it in perspective, AD sells Comand at 14k with GPS.
This is A STEAL.
any mercedes model can be retrofitted.
FULL INTEGRATION WITH INSTRUMENT CLUSTER
Guest Cerano
rssid wrote:
Any chance he can recode a non amg equiped car to work with paddle shifters ?
I'll check it out. I'm
hoping to get 5 guys at least for the comand Gb. This is a super cheap kan Tao
C&C sell 14k sgd
This one includes linguatronic too
Guest tls1212
C&C sell 14k sgd
so when the guy come down?
Guest Cerano
Should be brand new. His business is only installation of comand
however, you should note that the motorized button and central air vent cost an extra 180GBP. In our hot climate I think we should have it.
As for the W209, should be no problem
Guest tls1212
So the total will be GBP995 + GBP180 for everything right,beside this if not reach 5ppl for the GB so mean he wont come?
Guest Cerano
i have also posted in MCF and quite a few bros there have pmed me.
so most prob will hit 5 or so.
yes correct 995+180 unless you want the six cd changer or for comand to appear as a factory option.
Guest bbwannabe
very very good price!
even ebay also can be up to 3-4k sgd
what is his name?
hmmm... no one can program? w204 so different? autospritze did for my w203 fine (going to be +w211 also).
Guest Cerano
what is his name?
his name is mitesh.
yes no one can. MB has been locking up the SCN coding gradually. W203 no problem but W204 onwards...
kekeke but this fella quite expert
what is his name?
Let me guess his name, Milo? Kopi-o-siew tai? Horlick? Anyway, let me know the date and time when u guy going for the installation. I wanna kapo too.
Up for the good lobang!!!
Guest Cerano
No la not miro.
another fella. ok can
Guest jan999
bro, can confimred if my W209 can do? mine is pre FL, 2004 CLK240 Japan Spec. i already have an comand in my car, but since its in Jap spec, the gsp, tv, movie all cant be used.
Guest Cklasse5
I am very keen. Pardon me to ask whether could I add on the installation of rear-view camera and integrate it into this Command thingy?
I suppose after installation of this Command APS, we could get (1) DVD Video and (2) GPS, (3) Rear-view Camera (if possible), (4) Instrument Cluster Details from our Audio20.
How much would be the actual/specific cost in SG dollars if I want to have the (1) command fully installed with GPS and instrument cluster programming, (2) command to appear as a factory option on the vehicle's datacard, (3) Rear-view Camera (if possible), (4) motorised button & central air-vent and (5) Other miscellaneous spare parts that are required during the course of installation).
Next, when could we make this possible; any estimated timing? Where would we be doing the installation?
Please PM more details.
Cheers! :)
Guest Cerano
I need to confirm the numbers as to how many people. He will then arrange to fly down and install for us.
Comand APS + Instrument cluster programming + installation + GPS and linguatronic+ single cd changer - 2 083.70488 Singapore dollars
Motorised switch + central air vent - 376.951636 SGD
Comand to appear as factory option - 200SGD or so
Rear View Camera- He can do it. I already asked him. Depends on whether you already have an existing rear view camera. If not he can get you one. If you have one already, he can route it into comand but depending whether you have NTSC or PAL it will be in either colour or b/w
total for the basic motorised switch and comand install should be 2.4k all in.
installation is 1-2hrs per car and can be done over at a carpark.
Kindly put your name down below to confirm if you would like to join in this GB
GB closes on the 10/5/2010
1)
2)
3)
4)
5)
6)
7)
8)
9)
10)
Guest Cerano
W212 £1795 for single disc £2100 for 6 disc.
UCI for W204 & W212 is £600 if fitted with Comand. This gives you iPOD, A/V input and USB connectivity.
Old CLK W209 comes with CD Comand £900 fitted but no DVD. Not sure if you can get CD map of SG.
