W204 Carbon Fiber Paddle shifter for sale
Guest zavhan
Guest zavhan
Brand New boxed carbon Fiber Paddle shifter to let go.
For existing w204 with paddle shifter n wants the real carbon fiber look.
Also applicable for w204 (4 spoke steering wheel) those without paddle shifter as its a plug n play item. but u will need a reputable workshop to activate option on ur ecu.
Interested party can pm me. Reason for sale, car sold n forgotten I had kept it in store rm while trying to avoid CFO audit !! Will definitely consider reasonable offer.
Zav
  • Replies 11
Guest NewC180
AFAIK, it's not easy to install paddle shifts in the W204 if your stock doesn't come with it, though it is not impossible. Installation costs might be higher than the parts costs. Did some mini 'research' on this some time ago. Yes, I think Benzline can do it.
Is this what you're selling?
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=400113725305&pt=Motors_Car_Truck_Parts_Accessories&viewitem=&hash=item5d28a2ef79
Guest gavin
Checked with MBM before they said they cant do it. Autospritz has a method but requires running a wire from the paddles direct to the gear shifters cost approx $500+++++++++. Benzline not too sure tho
Guest NewC180
Yup, now I remember, installation costs is around there.
BTW, after fitting the paddle shifts, when you upshift or downshift, you won't be shifting the exact gears. Meaning that if display shows gear 3, it means that the gear will shift UP TO gear 3, and it is not saying that the car is in gear 3 now. So if you upshift to 4, the gear might not shift up immediately to 4.
Hope info will be useful to forumers that are interested in this mod.
Guest gavin
Yup its not manual mode as in the amg equipped cars more like a limiter of sorts exactly as the gear shifter method but allows you to keep your hands on the steering wheel and shift
Guest Cerano
i see. because bro zavier says any workshop that can check the option on your car's star diagnostic display can do it.
Guest zavhan
In tat case, guess only good for those who hav existing paddle shift and wan2 chg to carbon look applies. Sorry if i had mislead anyone. Item still avail if there r interested party.
