Help: Disable bluetooth mic by mistake
Guest kiat
Hi
Seems to have disable my car mic by mistake.
When there is any incoming call, by default the car stero will be muted. But I need to speak on the phone.
Is there anyway to turn back the mic?
  • Replies 3
Guest Clear Vision
No issue...i also "disable" many times by mistake.
Once you have connected by Bluetooth, just Press the Volumn button up (i.e. increase the volumn and the volume will come up).
To try out, alterantively, once there is an incoming call PRESS the volume button up first (button on the steering wheel right hand side).
Guest lockup
Hope you have already solved it. It happened to me once and I ended up doing a factory setting. Would work but not advisable as you have to reset everything like lighting all over all...
