Bulbs Story (Take 2)
Guest darkavenger
Guest darkavenger
Hi guys,
Mod my exterior lights again.
1. Philips HID (Dmg: $295)
2. Canbus T-10 LED (Dmg: $36 x 2)
- No splicing of wires needed unlike the other type that couple of bros here are using.
- 3 LED setup
- 6000K
So together with the HID......
If anyone else is keen, drop me a PM for contact. Not sure if it's against rules to post.
  • Replies 8
Guest lightning
darkavenger wrote:
Hi guys,
- 3 LED setup
- 6000K
hi bro...welcome to the club...i did mine thru him too...i kinda like my eyelid led...very white and blueish too...u also change your rear licence lights to led? if yes...is it bright enough? :whistle:
Guest darkavenger
hey.
i had HID at first.... then de-kit due to some issues.... finally took the plunge again...
my rear license lights still stock as mine is different from yours.... mine uses the fastoon type of bulb.
Guest darkavenger
btw, i think not possible to get the eyelids to be white.... suspect that the lamp housing is a little blue-ish at the eyelids...
the US forums are reporting the same as well.
Guest lightning
darkavenger wrote:
hey.
oic...i bought my rear licence led from Bimshop Steven...super bright...i suppose u install the decoder for yr HID too right? :whistle:
Guest darkavenger
nope. no decoder needed. ;)
so far, i know quite a lot of mercs w/o decoder. including my previous setup.
Guest lightning
oops...mine with decoder leh... i know many bros installed but din use ...he told me to play it safe and i agreed... for peace of mind...:whistle:
Guest darkavenger
haha. yah. he asked me if i want as well, i told him that my experience is that it's not required.... and if suay suay got error code... then i go back and ask him to fix.
Bru ah dark ride is CLC coupe. The rear licence plate bulb is festoon type not the same as sedan.
