Thermos thermal cooker rpc 4500- brand new!
Guest blackknight
Guest blackknight
Oringinal Price = S$ 326, I am selling $188.00 ONLY!:becky:
PM ME NOW TO DEAL!
For more information on this , please see description below:
Product Name: THERMOS® 4.5L Thermal Cooker
Model #: RPC-4500
The THERMOS® Thermal Cooker also known as the Shuttle Chef or cook and carry system, is a unique two piece cookware set that is enhanced by vacuum technology.
Features:
TherMax® double wall vacuum insulation for maximum temperature retention and lightweight transport
Practically unbreakable stainless steel interior and exterior
Energy efficient clad stainless steel inner pot for cooking
Cool to the touch with hot foods
Non-slip, scratch-resistant base
Bail handle for easy portability
Excellent for catered events, potluck dinners and tailgate parties
Can be used anywhere and any time. Cook even while you are traveling, boating, camping, etc.
Capacity: 4.5L / 4.7 Quart (4-6 servings)
Usage:
Assemble all the ingredients in the inner pot, put it on the stove and bring to a boil. Then remove the inner pot from the stove and place it inside the outer pot which serves as a vacuum insulated container to keep the contents hot. There is no need to plug in any power cord. The food will continue its “thermal cooking process” using the retained heat. After the required time (e.g. rice 30 min; chicken stock 2 hrs; beef brisket 3.5 hrs), just open the outer pot, and a nutritional and flavorful meal is hot and ready. The Thermal Cooker has excellent heat retention capacity; the food inside the pot can retain a temperature of about 160 degree Fahrenheit even after 6 hours.
Merits:
Safe: It is not a pressure cooker, there are no power cords, no switches or electrical hazards to worry about.
Energy Saving: After the food has been boiled for a short time, the cooker needs no external energy while thermal cooking. Food stays warm automatically after it’s ready.
Convenience: The thermal cooking process requires no further supervision or monitoring. Food can be cooked while you are traveling. You can cook with the pot anywhere, anytime and it’s safe to use indoors or out.
Economical: Decreases fuel costs, economizes time and energy.
Healthy: Entraps flavor, minerals and vitamins; generate less odor, grease and smoke in the kitchen.
User friendly: Never over cooks and cleans up easily.
Durable: Unlike foam insulation used in other brands, Thermos’s vacuum insulated outer pot is a technology that foam insulation can’t begin to touch. Thermos produces the most effective insulated container and is engineered to last.
How does a Thermal Cooker work?
Thermal cooker is a patented product of Thermos®. It is an epoch-making cooking concept, consisting of an inner pot and outer vacuum insulated container. The inner pot is a three layers structure: two layers of stainless steel with a layer of carbon steel of high heat conductivity. It is able to conduct and absorb heat quickly. The outer container is vacuum insulated. It prevents heat loss and is able to keep warm and keep cool efficiently. The cooking process is easy and safe.
