juggling wiper
Guest phicho
but i remembered there should be a stopper at the below of the reservoir that can be take out for draining one, later i go check see got or not.
Yes there is one, but u needs to bend..............down...............all the way, becareful when u do that, see any unker behind you or not!!!!
wahahaha...unker?? should be no unker lah, so i think i will drain it out using this method
East! I didn't know you're the type that like to bend down!!! Muahahahaha
bro, bend..........................down need skills one you know :twinmfinger: :1mfinger:...not easy one leh....muhahahaha
anyway i have not go look if got draining stopper, but if i am not wrong should have, coz previously when i own the W210 also have this, can pull out the rubber stopper & drain out all the washer fluid.
When bathing in the Ganges River and when that pc of soap slipped out of your hand, very dant gerous to bend down to get it back.....muahahahha
East for your size quite hard to bend down - U can report to Unker in Pleasure Island for training!....5 BX style.........hehehehe!
For sucking training, I can get good training with those "chug chug snails."
The small snails, that U used a pin or tooth pick to dig 1st, then put your mouth to the opening of the snail shell and start sucking away....muahahha!
Guest kmg4evr
Hi Guys,
Anybody had any luck changing their wipers to fix the juggling issue. Had C&C try and fix it but problem still persists.
Would be interested to see how this problem is permanently fixed. Or has everybody who is experiencing this just given up?
Thanks.
Hi Guys,
Thanks.
Did u try the method that we had suggested?
Hi Folks,
So far, I have tried diluting the wiper liquid with water and it seems to have lesser juggling effect on my wiper. I start to believe it is the wiper liquid. I may change to another type of wiper liquid once I emptied the original ones that comes with our car. Happy experienment to all.... (almost given up) :clap:
Hi Folks,
Good for you!!!!
Guest heavenknows
A friend told me that the foam used by some of those petrol kiosks manual car wash places have wax inside. So when they spray all that foam on your car, the wax is also applied onto the windscreen. This then contributes to the irritating juggling wiper!! :P
heard that too but it does not happen to the other jap cars.
Guest alumetal
Hi Bro,
I just send my w211 to C&C for svcing and also comment on the judder wiper.
They has the windscreen polished and so far the judder had stopped.
Will report more in due time.
Hi Bro,
Oh!!! Did you spray with the stock wiper liquid after the polish? U will know the result on the spot.
Unker, when bathing in Ganges, got soap or no soap makes no difference lah when u see the 'things' that share the river or floating about ...
Besides "chug chug snails", can also turn to tulang .... hmmmm straw also can !
Geylang Market & Hawker Centre got lots of soup tulang joints - near East's place.
After the soup tulang sessions, he can get real life practice at nearby GL joints.......work place, training place & practise place...all under 1 place....muahahahah!!!
East - Go take soup tulang tmr before U go Zaino session hor! :twinmfinger:
Guest east539
wah...why i bo tai bo ji kana arrow??? but unker, thank you for the soup tuuuulang recommendation leh, but i dun eat soup tuuuulang one, so no go for me.
