Camber joint
Guest daxchin
Guest daxchin
my friend is driving an euro r and got into an accident previously. after changing his left arm he is able to cruise in his car but unable to be as good as previously.
he went to some alignment shop and was told that his rims needs to be changed and more importantly his car is positively cambered??
and normal knocking is unable to help.
he was told to at least add a camber joint to make it neutral or negative camber, any help?
where is good.. how much? and does he need to change his front and back? or only front?
thanks a million in advance.
Guest Titan
To add a camber kit, it gives your ride a sharper handling during corners. Its good to have but not a must, it all depends on you.
Alot of Honda owners goes to Kenny at AMK autopoint. For alignment setting it is $40 and to add a set of camber nut should be in the range of $200 if the price is the same as 2 yrs ago where I have mine changed.
