Tyre Pressure
Merc Fan
  • Replies 6
On 06/11/2017 at 6:29 PM, joecamel said:
go pertrol kiosk and use the air pump. required pressures are prescribed in the fuel tank.
can tip pump attendant 2 bucks to help you.
Thank you! Actually, the issue is resolved by re-setting the tyre pressure on the speedometer as advised by C&C and no need to use air pump.
  • 8 months later...
21 hours ago, tituman said:
Hi guys, normally what pressure you pumped your tyres at? I usually pumped 250 kpa. Is that correct? Using standard 245 45 R17 tyres.
when you open your lid to your fuel tank, there should be a sticker that says what should be the correct pressure for your car and tyres.
  • 1 year later...
51 minutes ago, Yap Siew Fong said:
The pressure indicated on the filler is 300 kpa front and back for 235/45/R19 (for 5 pax). Is that the correct pressure? Through my years of driving, I have never come across pressure that high.
If ur Tyre size is correct then the label is right. U can use 280 or 290 also. Mine 18” is 270 back.
