Squeezing sound and Vibration
Hi ,
need some guidance and advice.
I drive a 4yrs old W204
1. Every time when I press my brake, I can hear a squeezing sound ( very soft, if u don't pay attention, u won't hear it , just that I'm fussy) i m using the ceramic break pad.
2. My car vibrates when I drive slow, eg: driving out from a carpark .
Any good mechanics/shop to recommend or shd I go back to CnC for advice ?
Or is it normal ? Or does anyone knows what is the cause?
  • Replies 4
Hi ,
1. If your ceramic pads still squeak after they have been warmed up, the squeak may be caused by a couple of other factors such as disc rotors not being flat, metal plate backing on the brake pads not sufficiently greased when mounted. Might take a few trips to your favourite garage to have it sorted.
2. Does the car vibrate similarly when you shift it into Reverse / Neutral or Park ?
Ic ic .. Any workshop to recommend ?
Vibrate only when I drive off.
Reverse/Neutral and park .. Okay ..
Again any workshop Lor ? Or shd I go back to CnC ?
Btw, my mileage is 60k plus only
The vibration is anyone's wild guess without having inspected your mounts, pulleys, injectors etc as there are so many different types of vibrations! :)
It sounds like you've always brought the car back to C&C so I would suggest you send it back there for an opinion and do checks on your cars subsystems to ensure everything is performing well.
Thanks .
