Reverse Camera
Guest KoolKai
Guest daywalker
hmmmm....
Has anyone tried "enabling" the reverse camera feature in our command unit so that we can simply install the reverse camera and make use of our existing display monitor?
Tks
hmmmm....
Tks
Think it will cut off the radio/CD once you engage reverse. :banghead:
hmmmm....
Tks
Dun bother, it will cost an arm & leg just to get the Composite to MOST bus interface...
hmmmm....
Tks
ya... also bought the reverse camera & went to a lot of installer to check if can connect to my built in monitor but they say cannot... so sad......
Guest daywalker
hmmmm....
Tks
ok thanks.
Reason I brought this up is because i recalled reading some threads in the US MB forums about this...but cannot remember the details
Hi friends,
The recent E200 Kompressor has a reverse camera and does anyone know whether the Merc has an extra monitor in the car for the reverse camera? :)
if i am not wrong the monitor is next to the rear view mirror on the driver's side. i know the monitor is there for the E230 but for the E200, some cars do not have, but some do...
Hi friends,
Mine was a factory add-on. Installed after delivery of the car due to no stock. right of the rear view mirror. thats probably the only monitor for reverse camera?
from wat i understand, the reverse camera monitor tat is located at the top right hand of the reverse mirror, is fitted locally from c&c. eventhough if u have the gps command system, the reverse camera cannot connect to the built-in monitor. dont have the extra cable to connect them.
Guest four_eggs
bro. i have installed the after market reverse cam and 2.5" TFT LCD monitor onto my new E Class. i imported many sets for friends and a few merz members got it from me. not that difficult to install the cam and monitor as they tap the wire from the reverse light and not the dashboard. u can call me at 96678989 if u want more info, cheers allen
I wonder how does the monitor's cable runs when it is being installed besides the rear view mirror? :bboyspin:
Hi 4_eggs,
How much does it cost to install the reverse camera?
Regards :bboyspin:
Bro, drop by later , 4.30pm onward @ Kallang car park 'F' and check out some of our bro's car, a few position of placing the monitor for you to consider.
see you
Hi friends,
Is it useful to have a reverse camera for the car? Does it really help? How much does it cost to install on a car?
Regards,
Kai :D
I got the C&C local fitted reverse camera (request free when book the car)... very useful because you can see the rear blind spot area. I think it is a night-enable camera... can see very bright view even at night and dark places.
Guest four_eggs
about S$100 for the full-set installation for merz. japanese cars at $80 by one audio shop in balestier.
Hi 4_eggs,
Regards :bboyspin:
