C180 confusions
davo
Good day guys,
Am looking for a used c180 cgi 1.6 or 1.8 mated with 7G tronics. Can anyone advise which will be a better buy since both hp are the same?
Also, was the 1.6/1.8 cgi 7g tronics introduced in 2010 or 2011?
I am confused becos i saw in sgcarmart there are some 2010 to 2012 c180 cgi 1.6/1.8 with 5AT.
Pls kindly enlightened me.
Thanks!
  • Replies 9
Facelift C180 started in 2011
Initially labelled as C180 Komp with 5at
then 2012 came the C180 with CGI engine but labelled 7g-Tronic to signifies the use of 7 speed gearbox
Facelift C180 should be 1.6 variant
2010 will be prefacelift model
those will be 1.8 litre
Oic.
So if im looking for the below what is the earliest year i shd look at? becos i intend to drive till scrap.
1. C180 1.6 turbo with 7G tronics >>> earliest year made - 2012???
2. C180 1.8 turbo with 7G tronics ... ealiest year made - 2010???
Thanks again!
Oic.
Thanks again!
w204 7 g gearbox was never fitted to the 180 range for pre facelift
it was seen in higher capacity like the C280/ C300/ C350
the 7 speed CGI 1.6 only in 2012 onwards (Facelift)
The 1.8 cgi With 7 speed will be C200 CGI ( facelift) sharing the same engine as the E200 CGI: Hp 180+
The 1.8 cgi With 7 speed will be C200 CGI ( facelift) sharing the same engine as the E200 CGI: Hp 180+ >>> May i know which year onwards?
should be same as the year FL version
2011?
not popular as it is quite pricey compare to the 180
PI brought in some C200 and it was priced about the same as C and C 180 Then
My ride is a C180 coupe registered in December 2011. It has a 1.8l turbocharged engine with 7G tronic gearbox. I believe there were also sedan versions then as I recall the 1.6l version only came after.
Yes, mine is the sedan version of your car. A C180 registered in May 2012, 1.8L turbo CGI engine with 7G Tronic gearbox.
It's more like a de-tuned version of C200.
At the time I bought the car, the 1.6L C180 has non-CGI supercharged engine and 5 speed gearbox.
The 1.6L turbo charged CGI with 7G Tronic gearbox came a year after that if I remember correctly.
