WTB - Engine enhancement for 3.2V6 M112 Engine
Guest etmusic
Bro, I think the probability of a fellow M112 3.2 V6 owner-enthusiast won't be very high so just in case you don't get any bites here, I thought I'd throw in a link for you (if you haven't come across it yet, if you have then :thumbsup:)
http://www.kleemann.dk/site/Main/performanceproducts/kompressor
Low boost - Incredible power output
The KLEEMANN Kompressor system for V6 (M112) and V8 (M113) engines is the very essence of the KLEEMANN slogan "Comfort Power." High power output combined with a low boost pressure of just 0.5 bar makes the system safe and provides long-term durability for the engine.
The KLEEMANN Kompressor System is an Eaton type supercharger with an integrated air-to-water intercooler and is the only known system to combine the intake manifold, kompressor and intercooler into one integral unit. The intercooler is such a superior design that it holds its own patent.
The system design was chosen because of its ability to develop boost at very low engine revs, and to maintain that boost consistently throughout the rev range until maximum engine revs is reached. As a result the engine has a characteristic smooth power band with no peaks or valleys - just immediate power on demand without any hesitation.
For nearly two decades KLEEMANN has manufactured kompressor systems exclusively for Mercedes-Benz engines. Since the beginning KLEEMANN has continually improved on its original design to offer the most efficient, powerful, and safe engine tuning solution. Today intensive research and development as well as the use of cutting-edge technology has turned KLEEMANN into the world leader in kompressor solutions for Mercedes-Benz.
The efficiency of the KLEEMANN Kompressor System is obvious. Mounted on top of a 5.0 litre normally aspirated V8-engine, it immediately enhances the engine's power output from standard 306 Hp and 460 Nm (340 lb-ft) to up to 455 Hp and 585 Nm (433 lb-ft), without any need for further modifications to the engine.
KLEEMANN Kompressor Systems are CARB and TÜV approved and are available for all models (1997- ) with normally aspirated (NA) V6 and V8-engine.
