reverse light indicator at rear windscreen not working
nocappucino
hi,
i'm referring to the one u see in the rear-view mirror, with the number, and the left/ right arrows (that changes green to orange to red).
seems like the right arrow light is not working. anyone else encountered this problem?
i've been living with it for past 3 months, but decided maybe shld go get it fixed. maybe at C&C since still under warranty.
btw, the reverse sensor is working, just that the indicator arrow is not lit up...
thanks!!
  • 1 year later...
  • Replies 5
That one has to go to the agent appointed by CnC. check with your SE they will let you know. Its under TOMO CSE. from what I know
hi dank,
yes, I got it fixed. went to MB Alexandra and asked service advisor to arrange for the installer (TOMO) to change it. it was a quick job, less than 30 min.
as for what it's supposed to do, it's supposed to give an visual indicator whether the rear is too close to an object (green = ok, orange = getting near, and red = WOAH!).
note that the number displayed is not indicative of distance...
i had called up the SE and he informed that i need to make an appointment, leave the car there for them to drive down to TOMO and get it fixed.
may i know which SE helped you get it done so fast?
thanks
i forgot his name liao, sorry! haha... but it took a while to get it fixed. he kept 'forgetting' to make appt for TOMO to come fix it.until one day i saw him while i was getting tire patched at MB Alexandra tire shop. then i reminded him.... and he finally got it done.
if u need to leave the car there, i think it's quite inconvenient. maybe u get him to come down to change? else... why not u get the address and u got directly to TOMO?
