Fuel Gauge Needle "Stuck"
salsa
Hi, just gotten my C200K 2 weeks ago.  On my 3rd top-up of petrol to full tank, the needle doesn't go up and is "stuck" at the 3/4 mark.
Any bros has this problem before? Any recommendations to solve this problem?
Done a search in this forum but cant find any related topics.
For advise pls.
Thanks in advance.
  • Replies 7
maybe can check with your dealer?
or go and check with workshop? Haven heard of such issue before
If u pump $20 bucks of petrol and the gauge does not move for sure your gauge got issue
i pumped at 1/4 tank.. the pump auto stopped, signalling the tank is full. when i started the engine, it only went up to 3/4 tank.. i tot was some error. so i tried pumping again... cannot liao.. tank full liao.. needle still at 3/4.
any recommendation of any particular workshop to go check?
i guess someone previously set the fuel gauge to "overshot" it so when going into JB , even low fuel it will show as 3/4 and wont get fined. i suggest u pump petrol to the max then manually set it back and see how it goes ;) hope it helps
thought of this as well.. will look up the manual to see how to set it back .
Thanks much for the advise.
