Merc disc rotor lifespan?
billcoke
My car has reached 50,000km+, I will be changing the disc pad, but should I change the disc rotor too? what is the disc rotor lifespan? What if I don't change the disc rotor? what is the consequence? will it crack?
C&C quoted $1900 to replace the pad + rotor.
What is the difference between the original Merc and OEM rotors
  • Replies 12
Are you referring to front or rear? 1900 seems expensive excluding labour.
My ex mistresses....
$1900 each or for 2 pair?
