Setting the Parking Position of the Exterior Mirrors on the driver and front passenger side
sw00sh
Can you actually do this to both driver and front passenger side, or just the latter? I have not try the front passenger side yet though, but tried on driver side to no avail.
I followed the instruction in the manual but using the driver's side instead of the passenger side, as I thought driver's side should be more the right one to refer to first. Is there a reason why even if its works on front passenger, why not driver side?
Thanks bros.
  • Replies 8
Does yr ride comes with memory seat function? If yes, the setting is only for passenger side only.
Your owners manual is not wrong but since the owners manual is for all vehicle type of your class for you own a C class the same manual is for the C180,C200,C250 , C300 C350 and so on but different models have different specification and equipments thus some of the things in the manual does not apply to you. And since your ride does not have memory seat, as this function pegged to the memory seat thus you do not have this function.
Yes, I understand that. I was looking for a statement that says that this is only for model .. and so.. or not applicable to model C180 base model or something to that extent. It did not hence I thought mine might have.
Anyway, good to hear if those C180 owners here have the same experience or not.
Cheers and thanks for the reply.
My C200 only works for passenger....I think the reason could be due to the fact that the driver can see the right side clearly as compared to the passendger side....
The Prize is a C200K sponsored by oldman
