anyone encounter these problems before (W203)
potpourri
Encountered some problems with my w203 at the moment...
1) prompted "dipped left beam". Left headlight no longer functioning. car look like a pirate now with only an eye. bulb blow? or maybe having other problems?
2) Went for car wash at noon and shocked to see fog light misty and got a small puddle of water inside. quite worried that may seep into electrical wirings but after awhile water was drained and fog lights no longer condensed. is it normal?
anyone encounter such problems before? will be sending my car for servicing tmr but want to get some heads up first. tks!
  • Replies 6
Normally it is a blown bulb, try changing the bulb I normally DIY my bulb changing a pair each time.
If change of bulb still have the issue it could been a blown fuse. In that case check your fuse chart and find the blown fuse and replace it. should be around $1 each.
for Q2 i do experience it before. As long the water do not fill to the bulb level you are safe. Normally i just wait for it to dry
Hi, my pair of left headlight and fog light not working. Prob blown. Can I know where to buy the bulb and how to DIY? It's actually strange that both left headlight and fog light blow at the same time.
