Leaves accumulated at radiator area?
chibibotto
Must be the W203 model.  I use a vacuum cleaner with a long attachment to vacuum out the leaves.  As for the W204, I do not have this problem of leaves accumulating between the radiator and the bumper.  Hope that helps.
Mine is w204. I took a look at some w204 at my place.. Some have this problem too. And one thing I observe is the radiator of those having this problem is touching on the floor board below the bumper while those without this issue have a gap in between.. Wonder why it is not the same for all..
Yes of course is the design. The stock fin gap is wider so chances of dead leaves getting into the radiator is higher.
I did for mine before....Vacuum cleaner.....
